Hello All,
I am a fairly new L2501DT owner. I have 4 to 5 hours on the tractor. When I received it, the fluid level was right in the middle of the sight glass. After two days (about 2 to 3 hours) I noticed that the level had dropped to about 1/4 the sight glass. At about 4 hours, I could not see any fluid. I added about 3/4 gallon and still do not see fluid in the sight glass. Is it common for a new tractor to have the fluid settle like this? I am about to add the remaining 1/4 gallon, but it I do not see fluid, then I need to go buy some more. I park the tractor in a garage on cement. There are no visible leaks.
My time on the tractor is fairly evenly split between the loader and box blade. On a side note, the coolant fluid has barely moved, grease looks good, all operations are fine with no noticeable new noise, and it uses about 2 gallons of diesel in 5 hours.
Thank you!
Rick
Thank you!
Rick
