Kubota BX23s problems
Aussie Steve
BX 23 s . 2018
Sep 3, 2021
Australia
Hi , my BX23S 2018 has a 4 in 1 bucket that has torn away from where the hydraulic cylinder ram is attached to the back of the bucket.
Is this a common problem.
Also leaking right rear axle oil seal.
Diff lock hard to ingage.
2,553
Steve
Welcome to the forum! Sorry to hear about your machine.
The only way that bucket broke at the mating point would be a bad weld - or bucket hit something rather quickly while backing up!
IF you have a picture - that would help us see what "may" have happened.
Leaking oil seal - may be as simple as the seal replacement itself - WSM will explain how to do that.
AS for the Diffy lock - sometimes you need to nudge the HST peddle to engage the lock - a small tire movement is needed to help the pin inside the differential to slide into the hole. Never allow the tractor to be spinning quickly while trying to engage - just a little nudge!
4,913
I agreewith 85Hokie...
bad weld. it'd only be a matter of time and use, before it'll break
seal,some kind of small,sharp 'grit' got into seal
difflock,heard if you turn while moving(very slowly), it'll help lock the dogs into the holes. Think nonsychronised tranny gears,you need to go slow to get them to mesh without 'grinding' them.
I'd like a 4in1 bucket, sounds like they're standard downunder,bet they're $$$$ here in Canada,IF available.
OrangeKrush
Nov 15, 2020
1,047
515
Indy
X2 on the differential lock while turning slowly.. learned that on here too and it works good. Sometimes you just gotta be patient and you'll get use to it.
4,816
I answered a 4 in 1 bucket question a few weeks ago, and wondered why Kubota didn't offer them in the states. I did find that Land Pride has one available for the BX, but the cost was a little north of 3K. Convinced me that I could live without it.
34by151
bx23s
Jan 12, 2019
166
46
Peachester, QLD, Australia
Where are you located in OZ?
Im on the Sunshine Coast QLD
The 4in1 bucket we get is an OEM Kubota bucket not a land pride one.
It weighs in at 82Kg which i think is less than the LP one
Its rare to see a machine without a 4in1 here
4,816
It is probably locally sourced, and a Kubota label installed as it rolls out the door. Just like the Kubota snow blowers are manufactured in Canada for Kubota by an independent vendor that also makes them for other companies. That is probably why Kubota bought Land Pride, so they would continue to have a steady source of products for their tractors.
