Removing Cowl Panel on M7060
tinygiant
M7060HD
May 12, 2018
21
GA
I'm trying to get to my messed-up brake pedals and parking brake lever. I need to remove the cowl panel and have found four screws holding it in, but there appears to be another attachment point at the top center of the cowl panel. There's no obvious screw/bolt from the engine side. There is no procedure or picture of this panel in the factory service manual or parts diagrams (that I could find). Does anyone have reference to how to remove the cowl panel/instrument cluster so I can access the brake pedal mounts?
tinygiant
M7060HD
May 12, 2018
21
GA
Do not know if this info from WSM will help you.
Thanks for the help. It ended up being self-critiquing. All of the bolts holding the cowl panel down are shown somewhere in the service manual, except for a single screw on the center of the cowl just above the instrument panel. Finally found it (covered in dirt and hidden). Took it out and everything came apart really easily. Thanks for your help.
