Barrel Handler
challer61
BX with numerous attachments
Aug 2, 2021
25
Central VA
I am looking for a barrel handler, all three standard diameters/heights 22.5", 18.25", 14" diameter. This is for a BX. This is home/light farm so don't need hydraulic anything. Your experience/best thoughts. Thank you!
3,557
2,026
4,913
vertical or horizontal ? on concrete or gravel ? short or long hauls ?
I made some 'donut' adapters to move small diameter barrels with a normal(PA) dolly..so 'one size fits all'.
Also modified a 2 wheel dolly to haul them,best to have 'flatfree' tires though !
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
Hello Challer61,
I used to work in the materials handling industry. Fork mounted drum handlers are common items. Adjustable units are available for 30/50 gal barrels. Maybe this link will get you started.
challer61
Aug 2, 2021
25
Central VA
Thank you. Saw the Goodwin and that is my leaning. Want to also get the smaller diameters as well. I will also be getting those dollies. While I've used Rachel straps for many things likely beyond their design limits, a dropped drum can be very bad (ask me how I know). It will mostly be lube, fuel and well, 223/308.
19thSF
Mar 1, 2020
408
123
If you go to the LK Goodwin home page and look at Drum Handling - All types you will find more ideas. Try using this link for even more ideas.
Good luck with it. Please let us know how you do.
"Only bird shit and fools fall out of the sky"
