Don't leave 4wd engaged all the time
4,509
You are making the comparison in a way that was not intended. But hey. It's someone else's tire.
We need a "Show your tires with 900 hours on them" thread.
I'm not worried about 4WD use as a major factor in tire life. I use 4WD because it is needed! The wear and tire replacement cost is just part of operation. I never think to myself, "Gee, I better take it out of 4WD or my tires won't last 900 hours.
nb. The tractor I use most has a locking differential in the front axle. That will cause some wear if left engaged on hard surfaces ;-)
Certainly not been a problem for me. My old B7200DT is never out of 4WD and has a couple thousand hours on the 20+ year old tires. The rears are well worn but still serviceable.
rbargeron
Jul 6, 2015
1,171
238
western ma
Tire wear is sure more with machines running a lot on pavement. My L3250's rubber is still good - but the L345 had a more paved past life and tires are pretty worn. Both have 2500+ hrs.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
19th SF - does your B2650 have the Bi-Speed option? From the WSM it doesn't affect any other gearing, only kicks in at high steering angle - so shouldn't be a factor here.
I haven't been able to verify the front-to-back axle ratio Kubota gave you, using parts lists and the WSM. I did notice B2650's have had 2 or 3 revisions of the final rear drive pinions (no tooth counts given). I must be doing something wrong but I can't find it.
No, no bi-speed option, and I do not believe that it is built in standard.
rbargeron
Jul 6, 2015
1,171
238
western ma
Found what I was doing wrong - I had a wrong tooth count in there - the ratio they gave you is right. And you're right bi-speed isn't built in standard .
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
195
160
Westford, Massachusetts
shelkol.com
Don't forget that leaving it in 4WD all the time adds stress to universal joints, differentials and transfer cases. I only use it when necessary.
19thSF
Mar 1, 2020
408
123
Thank you for your very knowledgeable feedback. I guess we can agree that the Kubota jargon for front to back axle ratio is "gear ratio".
I am also retired.............................................from a paying job that is, and there is still not enough time to do everything that I would like to. Or...........................maybe I just don't hit projects "as hard" as I used to!
