Just hit me yesterday if I'm harming anything. I have a bx2230 and some areas I like to cut in high gear and some in low gear. Is it too much strain on the hst or motor to cut in high gear? Seems ok by how it cuts and sounds but just making sure.
I bought my B1750HST new in 1993/4. Been mowing with a 60" MMM in high range probably 95% of the time since.Just hit me yesterday if I'm harming anything. I have a bx2230 and some areas I like to cut in high gear and some in low gear. Is it too much strain on the hst or motor to cut in high gear? Seems ok by how it cuts and sounds but just making sure.
Yep - - skeets and I both have BX2360's...a little newer than yours.WOT high no worries, unless you have some pretty steep hills then low, but yeah your ok
Do you run in high gear in order to get more speed than you can get out of the tractor than if you run in low gear with the directional pedal pushed fully down?Just hit me yesterday if I'm harming anything. I have a bx2230 and some areas I like to cut in high gear and some in low gear. Is it too much strain on the hst or motor to cut in high gear? Seems ok by how it cuts and sounds but just making sure.
