L3901 and 7’ box blade
2,551
Too big?
Well - it will really depend on the bite you wish to take! If pushing around gravel - might be fine - if digging dirt and moving a large chunk of dirt - then you might be loosing traction.
You 3 point should lift it ok - unless it weighs more than about 1800 lbs!
dosbirn
L3901, bucket, grapple, mower, forks
May 20, 2021
Memphis
Too big?
Mostly for gravel. I have no idea how much it weighs. 😁
DaveFromMi
L3901 RCR1260
Apr 14, 2021
610
530
Indiana
I have an L3901. I think a 6' blade would be Ok for it, considering that you may have to dig deep. 6' would cover the tire marks.
old and tired
L2800 HST; 2005; R4
So you think 7’ is too heavy?
Might be a tad too wide but not too heavy :ROFLMAO:🤪
I run a 6 footer on 28 hp; I could stop the tractor in it's tracks but I can also feather it so it fills up and I can move the dirt places. You really can't have it too heavy, the width (even though I joked about it above) is something to think about.
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
A 7' box blade by itself is not too heavy. Actually, a heavier box blade works better for many things. I have used a 6' on my L2501, but not extensively. I never loaded it up with soil though, but did put all the rippers down and it struggled to pull in some super hard packed material. You would probably be fine with it for gravel. You can always adjust it so it does not load up completely with gravel, or just lift the box blade to empty some of it if you need to.
UpNorthMI
May 12, 2020
850
568
Up North, MI
I own a 7’ box blade and an L3901, I would never consider putting the 7’ on the L3901, I use the 7’ behind my MX 5800.
I have a heavy duty 5’ that I use with my L series in the woodland, it works well and allows me to move and cut a lot of dirt. If you are only moving gravel, you may find that a 6’ is a good choice on the back of your L3901.
in my opinion 7’ is just too big on the back of an L series, yes it will lift it but it seems a little unwieldy.
dosbirn
May 20, 2021
Memphis
My husband agrees. He used it tonight. He told me he needs a smaller one. :rolleyes::LOL:
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Titan Forks, Caryall, 5' Tiller
Oct 26, 2019
214
376
Moseley, VA
I agree the I have a 5' box behind my 3901 and it is about perfect for the weight of the tractor with loaded R4 tires. A 7' will load up too much material and the wheels will begin to spin. This will mean more passes and frustration.
dosbirn
May 20, 2021
Memphis
Ok, so we’re buying a new box blade for the L3901 (replacing the 7’ box). The only thing we will be using it for is a 1,400 ft. gravel driveway & a 90 ft. diameter gravel turn-around pad.
Should we get a 5’ or 6’ box and light, medium or heavy duty?
UpNorthMI
May 12, 2020
850
568
Up North, MI
I woul
I’m a L3901 owner and run it with a heavy duty 5’ box blade, it performs very well. If I was only doing gravel driveway I would either buy a 66” or 72”, I suggest you buy a heavy unit, they should be at least around 500 lbs for this size.
Id be tempted to go 66” just to avoid it becoming cumbersome.
