Being new to tractors, I didn't realize that 3 point implements were not all Quick Hitch compatible. So far none of the implements I purchased are compatible. I have a QH 10 from Land pride, the implements I have are a terraform 72" tiller form EA and a finish mower from EA.
- the tiller has a bolt below the the upper 3 point attachment that prevented it from being able to be used. I moved the bolt further back to all the hitch to partially attach. the QH upper attachment is not adjustable, so it really doesn't align.
- the finish mower has a bracket on a pivot on the upper bracket. I believe it is designed this way to allow the mower to stay on the ground. The problem is the this bracket doesn't align at all with the upper hook of the QH.
Do other people have these problems? Would I have better luck with the QH15 with the adjustable upper hook? Are there adapters or modifications to help with this problem that people have had luck with?
