New forum member. I have a L3010HST with a quick attach front end loader using Pioneer-type couplings. The loader will roll the bucket just fine with plenty of speed and power but all of a sudden the loader arm function quit working and will only go down using the "Float" lever position. The raise arm function will work but very slowly and without much power. I removed the two hose quick connects that control the arm cylinders and made sure the coupler pins would press in and out on both the loader valve and the hoses. I also pressed the pin on the loader valve and ran the tractor using the lever and plenty of oil squirted out. I put the hoses back on and the loader acted correctly. 5 minutes later, same problem. Disconnected the hoses, pushed the coupler pins in and out, reconnect the hoses and ran the tractor loader for 20 min or so and now it seems fixed. I'm thinking I did nothing to actually fix the problem but don't know if it may be the loader valve or the couplers giving the problem. What do you think? Many thanks for any advice you can offer!
