Kubota D1105 3 cylinder in a lawn mower will run away if I let it. It cranks and runs without turning on the fuel. It has 350 lbs. per cylinder compression. Does anyone have a clue as to why this is happening?
I lowered the engine oil to the add oil dot, did not help one bit.
A little history, this pos came to me with a broken crankshaft, which wiped out the bearing cases. I installed a set of good cases, a reground crank, new rod and crank bearings, new rings after I broke the glaze on the cylinders, which measured with in wear tolerance, and all new seals.
Right now I am thinking that I might pull the engine and try a different brand of rings.
