I recently had the front axle apart on my B7100 chasing an oil leak, and a grumbly noise. The oil leak was a damaged gasket, and the grumbly noise turned out to be flogged wheel studs. Everything else in there looked almost new despite being made in 1976. All seemed to be running just fine again after I put it back together.
But, I now have no drive to the front wheels. I did have drive there, but not any more. I can see the prop shaft turning near the hydraulic filter in 4wd, and not turning in 2wd, so I'm confident that the problem lies further forward than that.
I think I heard what sounded like a spline not quite engaged in a socket and skipping across the face when I had it loaded up to see if it was actually working. I can't see how that could happen in the pieces i had apart.
So I'm wondering if there's a shearpin in that system somewhere i could have broken, or what the most likely scenario might be?
