Looking for some info on post hole augers. I am setting telephone poles in the ground. The widest pole is 13 inches and the rest are around 10 11 inches. I am wondering if a 12 inch auger bit will drill a bigger hole than 12 inches.
Rule of thumb on the pole crew it 10% of pole length plus two feet.Not sure how long your telephone poles are but anyone that I have installed I put at least six feet in the ground so they stay upright. Most augers I have seen will only go about 4 feet. I use my backhoe to dig the hole with it slotted on one side. I then tip the pole partially upright with my loader and the heavy end in the hole. I support it with some 4 x 4's and then go to the other side and pull it upright with a long rope. A crane would work better but I do not own one.
You do not say WHY you are setting the poles in the ground. If just spaced out to carry an electrical wire, alignment will not matter, but if you are using those poles for something else, like supporting a deck, or whatever, then unless you are REALLY good, you will probably need a little wiggle room to align the poles in the same plane.Looking for some info on post hole augers. I am setting telephone poles in the ground. The widest pole is 13 inches and the rest are around 10 11 inches. I am wondering if a 12 inch auger bit will drill a bigger hole than 12 inches.
