Can my B2601 handle this?
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
If you don't let the grass get too long between mowings it should work. If the grass gets too long it will bog down and you'll have to reduce your ground speed.
Old_Paint
Dec 5, 2020
1,732
1,728
AL
I'm not quite sure what they mean by 4/8" deck thickness. I'm relatively sure that deck shell is not made from 1/2" plate. It would weigh a wee bit more than 660 pounds if it was. But yeah, your B will definitely handle that mower, easily. I think I'd shop a little more for similar quality at a lower price ,though.
UpNorthMI
May 12, 2020
850
568
Up North, MI
These are nice mowers, Italian made. The deck is 4mm / 8 gauge thickness. Also sold by Everything Attachments at a similar price including delivery over a large part of the US.
Your B2601 can handle it depending on what you are cutting and how fast.
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
The B2601 has a 19.5HP rear PTO rating, The available mid mower deck on the B2601 was a 54" and 60", In my opinion a 72" rear finish mower is at the very top end of the limit for the available PTO HP.
With a 54" or 60" rear finish mower you would probably be able to cut the same amount of acreage faster and more efficiently with your machine than with the 72" finisher mower.
The link shows the specs on a 2017 B2601
https://www.tractor.com/reviews/kubota/2017-kubota-b2601-hst-review-1869/#:~:text=The Kubota B2601 is part,from 22 to 33 horsepower.&text=Rated to deliver 25.5 gross,at 2800 rpm, the 68.
BuckeyeStateOfMind
B2601 with LA435 loader, 60" QA bucket, and 60" Land pride box blade
Jul 15, 2020
21
Columbus, Ohio
Appreciate it. I have 4.5 acres that needs mowed, but I don't want to sacrifice speed as the whole point of a 72" over a 60" is to reduce time mowing.
Thanks for the info
3,299
As I recall a rough rule of thumb is 5HP for every foot of implement on the PTO I could be wrong though, cause things change all the time. Based on that 60 inch would be on the edge, a 72 might be a tad on the high side. Could you run it sure, if what you were mowing wasnt to heavy, could it lift it most likely, but the front end might get a little light. Just MHO, sometimes going big is not the answer
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
237
87
S.E. TN
It’ll handle it. But if your lawn is not flat, a six foot mower might not give a good even cut in some places. I cut about five acres a week with mine in the summer with a 60 MMM in med. gear with the go pedal mashed and it takes about 3 1/2 hrs. Comes out nice. EA551AF5-EBD4-4002-896F-13649830514E.jpeg
ngaoffroad
L4060HSTC, L3560HSTC, LP RCR2596, BH SQ84T, BH6, BH600SQ, Grapple, Tiller, Blade
May 31, 2017
Blairsville, GA
I ran a 72" Land Pride rear finish mower behind my B2301. Also had a 60" mower of same line. The 2301 cut pretty well with the 72", and very well with the 60". As long as field grass was mowed every two weeks there was never an issue. If let go for a month, I had to run the mower higher and a little slower, but that was true with both sizes. Did "ok" on moderate hills. The 60 was easier to move around obstacles. Both were nice because they definitely cut wider than the tires! I sold the 60 when I sold the little B. last fall. Still have the 72 but use it behind an L3560.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
With the number of zero turns on the market today you should be able to find a good used finish mower at a reasonable price.
