I was thinking of buying top n tilt for a new MX 5400. I've never had anything with rear remotes, so sorry if this is obvious. MX only allows 3 rear remotes, two of which would be used for top n tilt. What do you do when you have an implement that has two hydraulic functions? Can you disable the top or the tilt and still function manually on that adjustment? Or would you put in diverter switches to multiply the remotes as needed?.
Does having these remotes change anything about adding a front remote for a grapple? That's not a build option, so I assume that's just added using the Land Pride third function remote, but if you load up on rear remotes does that take up a connection needed by the Land Pride third function?
Thanks!
Thanks!
