Creature Meadow
First off I own a L4600DT with R4 tires.
I have a land plane, so the soon to be purchased box blade will not be used for road maintenance.
I intend to use it mostly for moving dirt, ripping up some roots in areas I have cleared and a ballast when doing loader work.
What width would you recommend buying? I live in NC and have a number of Everything Attachments implements and love the quality of them. The pick-up location about 45 minutes from my house. So brand is decided, now the width.
Should I get one slightly wider than the rear tires? I'm not concerned about covering my tracks so it looks nice. The areas when free of debris will be finished of with the land plane or tires I have bolted together to smooth.
Like the idea of it being slightly wider so I can get close to trees without rear tires scrubbing. But how wide?
Your thoughts on how wide to go and pros and cons to keep in mind.
My landscape rake and land plane have served well up to this point but upcoming project to grade and level an area where I'm moving a mobile home from I believe justifies the box blade. It will be used in near future grading other areas as well.
So what width do I order from EA Attachments?
My options are below.
Thanks for your time.
Jay
No code has to be inserted here.
Jay
