Hi all. I purchased my L3901 new almost a year ago. So this is my second winter with it. I store it an unheated shed. I'm diligent about letting it warm up for 20-30 mins in cold weather. On cold days, I would say maybe under 20 deg (F), I notice what I would describe as more than a few drips but less than a pool on my shed floor after warm up. The liquid is slightly greenish. It seems thicker to me than coolant. From a visual perspective, I cannot figure out where it is coming from. Admittedly, I have always had the need to get working, and then after working I don't want to run my hands in and around things when it's hot, so I haven't figured out the source. I do check my fluid levels to make sure I'm ok to run it. What do I need to worry about or fix?
It's coming off the left side. Picture is attached. You can see the fluid accumulated on the zip tie. Given it's on the outside, and I can't see anything obvious above it, I was thinking maybe it was spraying on the inside of the hood and then dripping, but I didn't see evidence of that.
Thanks for your help!
