Nothing beats rapid oxidation promoted by an accelerant. I pile it up until it's a big pile, add some used motor oil and a match and let it go...
If you're using it a lot and want to use your tractor at the same time ie for the grapple the stand alone has merit. If you don't need the tractor at the same time and don't want another engine to maintain the PTO driven unit becomes more practical.A 3-point PTO chipper vs. a standalone, why would you choose one over another?
I'm looking at getting one, but I'm not sure I want a PTO one. It would mostly stay in one place, where I do my composting. But from what I've read here, it seems like the PTO one gives more capacity and power for the price? (That would make sense since you don't pay for the engine)
What should you consider when deciding on what to get? (that hasn't already been covered)
I'd prefer a 12" diesel self powered autofeed unit. For the amount of chipping I do it isn't cost effective.A 3-point PTO chipper vs. a standalone, why would you choose one over another?
Bigger units with power feed handles large branches without having to cut them up. I want less work not more.I've pondered a wood chipper a few times and the one thing that always pops into my head: why turn good firewood into mulch?
I would want the bigger unit because that's just how my brain works, but then I think I'd prefer to cut most of the larger stuff into firewood and only chip the smaller stuff, meaning I'd have a way bigger chipper than I really need.
Ditto. Any wood over 4" goes for firewood around here anyway. Plus my 19.5 HP pto will only handle chipping up to about 4" anyway.I've pondered a wood chipper a few times and the one thing that always pops into my head: why turn good firewood into mulch?
The advantage of the larger chipper is not that it ‘can’ take larger sticks, its also that sticks and limbs are never straight and full of crotches and Y’s. With the bigger capacity machine you can stuff all that crooked material through without having to trim it down. Or not limb small trees at all. I haven’t put much bigger then 4-5” stuff though my 8” capacity chipper. But a 4” balsam with the limbs on will barely go through sometimes, but not having to saw any limbs off sure saves time.Ditto. Any wood over 4" goes for firewood around here anyway. Plus my 19.5 HP pto will only handle chipping up to about 4" anyway.
My tractor hp is at the bottom of the range for the WC68 so anything larger would be a waste and probably harmful to my tractor imo.The advantage of the larger chipper is not that it ‘can’ take larger sticks, its also that sticks and limbs are never straight and full of crotches and Y’s. With the bigger capacity machine you can stuff all that crooked material through without having to trim it down. Or not limb small trees at all. I haven’t put much bigger then 4-5” stuff though my 8” capacity chipper. But a 4” balsam with the limbs on will barely go through sometimes, but not having to saw any limbs off sure saves time.
Not likely to hurt your tractor, but you will probably run out of horsepower if the chipper's too big, or more correctly, if whatever you're feeding the chipper is too big. If all you're feeding it is brush (<4"), what does it matter how big the opening is. Feed it just like you would a smaller chipper, recognizing, of course that you may not have to cut up as many brush tops. Typically, one with a larger opening is also going to have a stronger draft, and blow the chips a little farther out.My tractor hp is at the bottom of the range for the WC68 so anything larger would be a waste and probably harmful to my tractor imo.
Much over 4" depending on the wood will over tax the tractor anyway. The way I see it, this chipper should last a very long time.
The variable-rate hydraulic infeed is quite good at pulling branches and tree tops through, and if it stalls i can usually give the wood a nudge and off it goes. By now I know pretty well what won't make it, and trim those branches.
But it's very satisfying when you lift a 4" at the base 30 ft long poplar tree up into the chute and it gets grabbed and the whole thing goes through. Lots of time to scope out the next load.
I'm very happy with my tractor/chipper combo. Just right for my needs!Not likely to hurt your tractor, but you will probably run out of horsepower if the chipper's too big, or more correctly, if whatever you're feeding the chipper is too big. If all you're feeding it is brush (<4"), what does it matter how big the opening is. Feed it just like you would a smaller chipper, recognizing, of course that you may not have to cut up as many brush tops. Typically, one with a larger opening is also going to have a stronger draft, and blow the chips a little farther out.
If you want something that runs faster than 540 RPM, you might consider one of the hydraulic models that runs off a PTO driven pump with separate oil reserve. That will keep a lot of heat out of your tractor oil.
I've been looking at a LOT of different brands, and so far, the mechanicals and construction of the Woodland Mills products seems a few notches above anyone else. And the pricing is very competitive, if not one of the lowest for similar size and feature equipment. I compared one at similar price from another brand, and the features and quality didn't even come close. I also looked at their sawmills. Same thing, quality/construction a few notches above the rest for the same price, or maybe even a couple hundred less. I guess if you make a good product and sell lots of them, you don't have to gouge your customer as hard? What a concept.I'm very happy with my tractor/chipper combo. Just right for my needs!
Based on my experience, a face shield is a good idea as well.They are extremely loud... and chunks fly... Eye protection and hearing protection are a must have!!!
