Thank you for your reply sir. To your points, I took a good visual all the way around and saw nothing at all as a possible cause. I was using the tractor to pull a vehicle out of the way. Got'er dun and no problems at all. Disembarked and it looked funny then realized that the tire was completely off the bead. So, like you said, I should just take to a shop.Well, you have a couple of options, but it is dependent on what caused the flat.
First, do you know what caused the flat?
If it is a screw or thorn, you can self patch, but if you don't know how, it can be a little challenging.
If the tires aren't loaded, you could use a product like TireJect AmazonSmile: TireJect Tire Sealant Kit - Fix and Prevent Flat Tires (40oz): Automotive
If the tire is off the bead, you best bet is to take it to a tire shop.
If your skills/experience with tires are limited, the easiest and safest way to do it is as BAP pointed out to take off the tire and have the local tire shop fix it.
Excuse me Bmyers, a question. The product you suggested, I see that it is a sealant but don't I need that trick where they make the small explosion while simultaneously putting air in? Or something like that.Thank you for your reply sir. To your points, I took a good visual all the way around and saw nothing at all as a possible cause. I was using the tractor to pull a vehicle out of the way. Got'er dun and no problems at all. Disembarked and it looked funny then realized that the tire was completely off the bead. So, like you said, I should just take to a shop.
Btw, congratulations. You are my very first message on this site! LolExcuse me Bmyers, a question. The product you suggested, I see that it is a sealant but don't I need that trick where they make the small explosion while simultaneously putting air in? Or something like that.
I appreciate the advice. Now, to the next problem. How does one operate a jack?? Ha, just kidding. Once again, thanks a bunch and have a good day sir.Btw, congratulations. You are my very first message on this site! Lol
That's cool. I called around and got several ridiculous estimates, $90 and more. Eventually I called the tire shop in town right on main street. They said $30. That's a good price, right?I have used heavy duty ratchet straps before run around center of tire to put pressure on side wall and filled with air. Worked on car, truck, 4 wheelers tractor tires etc. But if already off. Bead worth taking a look inside visual for cracks holes etc. Or you can put a tube in it. Personally I dont take much to a repair shop unless I can figure it out or am swamped and need asap. But it's your wallet not mine.
For 30 bucks that's cheap.That's cool. I called around and got several ridiculous estimates, $90 and more. Eventually I called the tire shop in town right on main street. They said $30. That's a good price, right?
I think that is a great idea. I can follow all of your instructions as I'm a newbie but not a complete idiot. Lol Since I'll have to jack it up anyway I'll give it a whirl and see what happens. I'll give you a holler and let you know how it turns out if that's ok.That's cool. I called around and got several ridiculous estimates, $90 and more. Eventually I called the tire shop in town right on main street. They said $30. That's a good price, right?
I'm glad you mentioned how you used the bucket as a jack because I had already had an idea that's the same thing only backwards. I was thinking I would just put the bucket up under something way to heavy and slowly lift the rear end up instead. It doesn't have the fluid in the rear tires as of yet so it's pretty light in the ass. Lol Since my step dad got too old and frail, he recently handed the tractor and the responsibilities down to me. They say give a difficult job to a lazy man and he'll find an easier way. Lol I just don't know if that's actually a good idea or a recipe for disaster! Can I do it that way then use the car jack's for safety purposes?Jump on that $30 before his coffee kicks in!!
For front tires, I rolled my front tire off the bead. Used front end loader to lift it off the ground, wrapped a ratchet stray around the middle of the tire. Shintched it up tight. Aired it up, released the strap a little bit, added more air... then totally released the strap.
That sounds exactly right and I'll do exactly that but I was kinda looking forward to that explosion thing. Ha!Do you have a large air compressor? If you do you may be able to jack up the tire to see if the tire will flex back into shape. If it does you can try to see if it will take air. Make sure everything around the rim is clean. You may be able to place a ratchet strap around the circumference of the tire fasten the 2 ends together and tighten the strap. If this brings the rim and tire together then place a small amount of air in the tire. Release the strap and then fill the tire to the correct pressure. Use a spray bottle with water and a little dish soap in it to spray the tire and find the leak.
I have a fairly small air compressor btw. It came with the tractor!That sounds exactly right and I'll do exactly that but I was kinda looking forward to that explosion thing. Ha!
It's not loaded at all.Tire shop. If loaded, find one that deals with loaded tires
