Backed off of trailer put in forward moved about 15 ft and stopped moving. It will only move forward or backward in 4WD! Help please
I would have guessed the RTV was front wheel drive and used the rear wheels only in 4WD. But I do not have a clue and look forward to learning more in this thread...It sounds like a rear drive shaft is broken or disconnected.
I don't know about that particular vehicle either but I can imagine a drive train that is rear wheel in 2wd and front wheel in 4wd. It is possible that there may even be a carrier bearing halfway between the transmission and the rear differential. I tried looking at a parts diagram in Messicks but I must open an account to do that and I don't want to open one.I would have guessed the RTV was front wheel drive and used the rear wheels only in 4WD. But I do not have a clue and look forward to learning more in this thread...
It’s Definitely Rear Wheel Driven HydrostaticI don't know about that particular vehicle either but I can imagine a drive train that is rear wheel in 2wd and front wheel in 4wd. It is possible that there may even be a carrier bearing halfway between the transmission and the rear differential. I tried looking at a parts diagram in Messicks but I must open an account to do that and I don't want to open one.
In that case I would suspect a broken U Joint or or CV joint, whichever they use on that vehicle. There is a slight possibility of a rear differential problem but that is unlikely because he said that it drives in 4wd. If he does not hear noise from the rear differential then it is not likely the problem.It’s Definitely Rear Wheel Driven Hydrostatic
It is common for the RTVs to strip out the splines in the hub.I'm not sure how they are configured but I know the Kawasaki's sometime strip out the splines on the rear hubs and they will not drive when this happens. look at both rear axle shafts when trying to drive in 2WD and see if they are spinning
In this case would the OP hear a noise from the rear end and maybe even feel some lurching while driving?It is common for the RTVs to strip out the splines in the hub.
Not if the splines were cleanly stripped out and the preload on the hub for the axle nut were loose. The axle would just turn smoothly inside the hub as if one tire were off the groundIn this case would the OP hear a noise from the rear end and maybe even feel some lurching while driving?
Thank you. I was thinking about buying a Kubota RTV900 and what you said about the axle splines having a propensity to strip out has me re-thinking going with Kubota. I was also looking at the Kioti offerings. I want to stay with Diesel powered but I want to stay well away from JD.Not if the splines were cleanly stripped out and the preload on the hub for the axle nut were loose. The axle would just turn smoothly inside the hub as if one tire were off the ground
WhiteTiger does contribute such helpful information here! Highly appreciated.Thank you. I was thinking about buying a Kubota RTV900 and what you said about the axle splines having a propensity to strip out has me re-thinking going with Kubota. I was also looking at the Kioti offerings. I want to stay with Diesel powered but I want to stay well away from JD.
Thanks for all the information you provide.
I actually confused Ruger1980 with WhiteTiger. I had what Whitetiger said in mind when I replyed to Ruger1980's post.WhiteTiger does contribute such helpful information here! Highly appreciated.
But before NOT buying a RTV, I would ask what "common" means with respect to stripping out the rear axle splines, and how big of a deal it is to repair if this happens.
There are many RTVs out there, and it seems like not too many reports of this being an issue. BUT I do not follow any RTV forums, so what do I know?
OPPS! Confused lugbolt with whitetiger! edited post to correct. Both are outstanding at helping us here. So my confusion is understandable...
Probably not. When the splines shear off, the inside of the wheel hub is smooth. The axle shaft can just spin freely.In this case would the OP hear a noise from the rear end and maybe even feel some lurching while driving?
I did not mean to imply they have a "propensity" to strip, it happens to a very low percentage of RTVs. It is a failure that can happen to any unit no matter what brand.Thank you. I was thinking about buying a Kubota RTV900 and what you said about the axle splines having a propensity to strip out has me re-thinking going with Kubota. I was also looking at the Kioti offerings. I want to stay with Diesel powered but I want to stay well away from JD.
Sorry for the use of the word propensity. You did not say that but I used it because that fit my understanding of it being a common occurrence.I did not mean to imply they have a "propensity" to strip, it happens to a very low percentage of RTVs. It is a failure that can happen to any unit no matter what brand.
But I thought he said (or implied ?) it was not a common occurrence...Sorry for the use of the word propensity. You did not say that but I used it because that fit my understanding of it being a common occurrence.
Anyway, it is my belief that it should not be a common occurrence. That to me indicates a need for re-engineering.
