Washer fluid pump
Thunder chicken
M7060
Dec 29, 2019
295
120
Northern ontario
I need to replace a washer fluid pump on the M7060. Of course you can’t buy just a pump from Kubota, the whole complete tank is available for hundreds of dollars tho.....
I guess the world wouldn’t go around without there being 367 different sizes and styles of pumps out there, Has anyone else replaced a pump, found a specific one that fits the hole in the tank? I have to mail order anything I get, unless it’s a generic one from out local auto parts store, and he’ll have to order one so it’ll be mine if it fits or not... i suppose a grommet kit / plugging the old hole and drilling a new hole is always an option too.
3,557
2,026
The best you can hope for is to try and disassemble and find a part number. The ones I've come across have been sealed units and it's easier to replace the whole unit. You might find an alternate model that fits your location.
4,913
a possible option.. replace the whole tank with a car/pickup truck unit ?? A friend replaced tank in his truck with a windshield fluid jug and inline pump. He plowed snow and want LOTS of fluid. Depending on shape,size,configuration ..it might cost you $20 at a wreckers for a tank unit. If you go that route, by a 2nd one for a spare !
200mph
Mar 3, 2017
1,228
61
PA
Out of curiosity, looked up the part at Messick's and it is $187.28, which is crazy to replace a washer pump motor. What I find interesting is that they have 15 in stock. That seems like a high quantity to have in stock unless their are a lot of pump failures.
The Tank assembly is used in 67 different models. Perhaps one of the older parts contained a pump only part number that could be used to find a Pump Only... Just a suggestion.
Here are the other models this is used on in the event it helps. At a minimum it gives more opportunities to use your favorite search engine.
Report back if you ever find one.
(Now I understand why they have so many in stock, give the plethora of models it fits.)
L3240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009)
L3430DT / GST / HST(C) (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission) - B42001 WASHER TANK [CAB TYPE] [A]
L3430DT / GST / HST(C) (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission) - B42002 WASHER TANK [CAB TYPE] [CA]
L3540HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009)
L3560HSTC-LIMITED
L3710DT-HST-C - B42001 WASHER TANK [A] [CAB TYPE]
L3710DT-HST-C - B42002 WASHER TANK [CA] [CAB TYPE]
L3710DT-HST-C (Cab) - B42001 WASHER TANK [A] [CAB TYPE]
L3710DT-HST-C (Cab) - B42002 WASHER TANK [CA] [CAB TYPE]
L3940HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009) - B42001 WASHER TANK [A]
L3940HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009) - B42002 WASHER TANK [CA]
L4240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009) - B42001 WASHER TANK [A]
L4240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009) - B42002 WASHER TANK [CA]
L4310DT-GST-C / HST-C - B42001 WASHER TANK [A] [CAB TYPE]
L4310DT-GST-C / HST-C - B42002 WASHER TANK [CA] [CAB TYPE]
L4310DT-GST-C / HST-C (4wd, Cab) - B42001 WASHER TANK [A] [CAB TYPE]
L4310DT-GST-C / HST-C (4wd, Cab) - B42002 WASHER TANK [CA] [CAB TYPE]
L4330DT / GST / HST(C) (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission) - B42001 WASHER TANK [CAB TYPE] [A]
L4330DT / GST / HST(C) (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission) - B42002 WASHER TANK [CAB TYPE] [CA]
L4610DT-HST-C (Hydrostatic Transmission, 4wd / Cab) - B42000 WASHER TANK [A] [CAB TYPE]
L4610DT-HST-C (Hydrostatic Transmission, 4wd / Cab) - B42001 WASHER TANK [CA] [CAB TYPE]
L4630DT / GST(C) / HST (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission) - B42001 WASHER TANK [CAB TYPE] [A]
L4630DT / GST(C) / HST (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission) - B42002 WASHER TANK [CAB TYPE] [CA]
L4740HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009) - B42001 WASHER TANK [A]
L4740HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009) - B42002 WASHER TANK [CA]
L5030GST / HST(C) (Glide Shift Transmission / Hydrostatic Transmission) - B42001 WASHER TANK [CAB TYPE] [A]
L5030GST / HST(C) (Glide Shift Transmission / Hydrostatic Transmission) - B42002 WASHER TANK [CAB TYPE] [CA]
L5240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009)
L5740HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009)
M-110DTC (Dual Traction, 4wd / Cab)
M-110FC (Two Wheel Drive / Cabin)
M-120DTC (Dual Traction, 4wd / Cab)
M-120FC (Two Wheel Drive / Cabin)
M4D-061HDC12
M4D-071HDC12
M5-111HDC12 / HDC12-1
M6-101DTC
M6-111DTC
M6-131DTC
M6-141DTC / DTSC
M6060HDC
M6060HFC
M7-131P
M7-131P KVT
M7-131PB
M7-132P
M7-132P KVT
M7-132S
M7-151P
M7-151P KVT
M7-151PB
M7-151PB KVT
M7-151S
M7-152P
M7-152P KVT
M7-152S
M7-171P
M7-171P KVT
M7-171PB
M7-171PB KVT
M7-171S
M7-172P
M7-172P KVT
M7-172S
M7060HDC12
M7580DT-C (Dual Traction, 4wd / Cab)
M8580DT-C (Dual Traction, 4wd / Cab)
M9580DT-C (Dual Traction, 4wd / Cab)
M9960HDC (Hydraulic Shuttle, 4wd / Cabin)
MX5400DTC
MX5400DTHC
MX6000DTHC
R420S
R430
R520S
No code has to be inserted here.
Thunder chicken
M7060
Dec 29, 2019
295
120
Northern ontario
Thanks for the input and ideas. There is no number on the pump that means anything. I’ve measured the inlet nipppe and will email an aftermarket pump outfit and see what one is close.
I thought about the auto wrecker route too :) Kubota in all their wisdom put 2 pumps on this one, for redundant safety I guess.... but no matter what I find ill have to cut the connectors off so may as well find a dual outlet pump. The added bonus is the auto jug will have an easily replaceable tank cap, unlike the tractor and it seems these lids fall apart in short order. (I had a guy 3d print me a new one but...)
SidecarFlip
Banned
555
M M9 cab also has 2 pumps. One for the front glass and one for the rear glass. They appear to be identical.
SidecarFlip
Banned
555
try 1A Auto. Shipping is always free. Compare prices including ship cost and then purchase.
3,316
I knew there was at least one reason an open station is better than a cab.
retired mac
M4900 tractor
Jul 17, 2021
Tuscola Tx
