Thanks a million for all the replies fellas, it is greatly appreciated. Today I checked and verified ALL grounds, connections and cables. Every one of them, unless I missed something, is fine.
Looking at the wiring diagram {strange that it doesn't show a 40 amp main fuse, which I replaced anyway} I don't see anything that would stop this tractor from cranking over even if the OPC system is open. It appears that the OPC system disables the fuel solenoid so the tractor either: A. cuts off if it's running, or: B prevents the engine from starting for lack of fuel. It does not appear to have any means to prevent the tractor from cranking over.
Unless the wiring diagram is incorrect and failing to show other components like that fuse, I see nothing that can stop it from cranking over and dash indicator lights to light up if there is power to the ignition switch.......which brings me to a bad switch right out of the box!!!! I have not had time to test it yet, but first thing tomorrow I will. Thanks again for all the replies!!!!
