Hello all, first post and I need some help figuring this thing out. Rather than post a long, drawn out story of what lead up to this tractor dying I will post the basics of what's going on first. I have found some other things that needed correcting, but I don't want to confuse anyone. Had it since new and never had any electrical problems before. I don't use this tractor every day, more like once or twice a week. In the last month or so it started stalling. Totally random and could happen anytime or run all day no problem. Sometimes it would just slow way down for a few seconds and rpm's would go right back up but sometimes it would cut off. Never, not once did it ever fail to immediately restart. The engine runs perfectly and the machine only has like 500 hours on it.
Because the tractor runs so good and would start so easy I really believe this is some simple stupid electrical problem and I looked at all the OPC safety switches. Seemed to all work fine and tested okay with a volt meter. Next day I went to use it and it would not crank. In fact, all that happened was the indicator lights in the dash would blink momentarily and go right out immediately.
The ignition switch just didn't feel right, it felt like it was full of gravel and not smooth so I replaced it with a new one. Now the dash lights no longer blink and the tractor does absolutely nothing. No sounds, no clicking, no lights no, nothing, with the exception of the key being moved that is it, zero. The battery is about 6 months old and measures 13.1 volts. I measure 13.1 volts at the ignition switch. What lies between the ignition switch and the starter solenoid that can cause this condition??? I bypassed the time delay relay for the OPC system when it was stalling and the tractor would start up and run, but still stall. I have again bypassed it but no change so I don't think that is the problem. No fuses are blow and the big 40 amp main is good.
Any help is greatly appreciated and thanks in advance for reading this.
