Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
I changed all the fluids in the B2410. Replaced the mid PTO seal along with one axle seal... no more seeps!
This is where I need some opinions.
I also replaced the engine coolant with Valvoline Zerex g-05. as recommended for diesels. Instead of using the 50/50 method I went with 70/30 mixture guide. I did it not so much for the lower freezing point however I kind of liked the idea of the higher boiling point. My rationale was if the engine would ever overheat (which it has never done thus far} the higher boiling point would help protect pressure build up if it did until I could take measures to reduce the temperature on the gauge.
Given the lack of coolant specifications on the Kubota engine I went with the Zerex g-05. Did I screw up?
