Battery charger ?
David H
L185
Oct 31, 2016
73
Auburn Hills, MI
Hi all
Accidently charged my conventional battery with the charger set for AGM battery.
Did I damage battery too much or at all.
I googled the heck out of it and could not find an answer.
Thanks David
4,816
You took a couple of years off of its life, but you won't know how many until it dies. I wouldn't worry about it. Better to charge a conventional battery in AGM mode, then charge a AGM battery in conventional mode.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
Just a question what does the AGM mode do/?
More current or voltage?
Thanks David
AGM batteries shouldn't be charged as quickly as conventional LA batteries so the AGM charges the battery more slowly. so usually less amps
4,899
I seriously doubt you did any harm....
according to a Google search conv. bat is 12.70 v, agm is 12.80 v
that .1 v 'over charge' might not even have occoured.
first what 'charger' did you use ? 'smart','trickle','SCR', 'stupid' ? There's at least 11 types of 'chargers' I've designed/built/repaired over 45 years.
2nd, what DVM do you test voltage with ? EVERY DVM/DMM is +-1 digit. So if it reads '12.7' it could be 12.6 to 12.8. Nature of the beast, NO exceptions.
3rd, what battery ? capacity and age are important factors, as it room temperature where charging was done. Depending on mfr/mdl/cap/age of battery it will require different charging methods to properly recharge the battery.
Jay
6,351
Yep, no harm done at all, if anything it's a better way to charge a regular lead acid battery. ;)
David H
L185
Oct 31, 2016
73
Auburn Hills, MI
It was a harbor freight batt charger that has 2 amp 10 amp and 50 amp jump starter.
was very inexpensive but needed jump starter and old scumacher did not have that.
I do not know a great deal about the different voltages it produces.
It was about 40 deg for car and tractor batteries.
age of batt is about 3 to 4 years
propuckstopper
GR2010, BX2380
Jan 10, 2018
37
Hi all
Thanks David
Your battery will be perfectly fine. No harm done using the slower charge rate of the AGM setting. Breathe easy.
