I don't understand the AV or RV as they pertain to ring gap. The top compression ring should have a wider gap as it sees more heat and has greater expansion. The lower compression ring may have a tighter gap as it doesn't get as hot or expand as much. Check out this explanation: https://blog.wiseco.com/everything-you-need-to-know-about-ring-gap
