Gene Blister
2019 Kubota B2601, FAL LA435, Snow Blower BX2822A, Land Pride rear blade RB1572
I just did the 50 hour maintenance cycle on my 2019 B2601. I drained the factory crankcase oil and installed a new filter. Refilled with Zecol Max Pro Series 10W-30.
Unfortunately, I was so locked on the oil's weight I missed the small notation "For Gasoline Engines" at the bottom of the label.
Now when I start the engine there is a brief, light puff of black smoke. I have been using the FEL to move rock and sift gravel from soil, with frequent starting the engine, running for a few minutes and then shutting it down.
I run the gloplugs for 2-3 seconds before each start up, and have the RPMs up to 2000-2200 now, after keeping them below 2000 during the break-in period.
Have I messed up with the wrong oil in the crankcase? Is a puff of black smoke normal at start up? It hadn't happened before....
