Help, Part Is NLA from Kubota, Need options on how to proceed
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,123
1,244
Near Lancaster, PA, USA
The Caroni quills have 4 bolts and mount to the flat part of the deck. Below is a picture of the bottom side of the 91" Caroni I restored earlier this Summer.
haanzel
L2600DT, G4200 mower
Jul 30, 2014
122
On that link you posted, is the top side shown where the blade goes?
SidecarFlip
Banned
555
Guess who sells all the Caroni parts? ASC. Agri-Supply and they have an online website.
chim
Jan 19, 2013
2,123
1,244
That picture is right side up. The blade goes on the bottom and a sheave on the smooth top part. There is a key for the sheave that must be on the back side as shown.
Yes. See post #15
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
Wow, that is a GREAT IDEA! I guess that would mean I'd have to get a drill press :)
Lathe. Drill press is not accurate enough.
If you were closer, I'd do it for you. But shipping would be a killer.
haanzel
Jul 30, 2014
122
Thanks for the offer. I will post back what I hear from the shop. While this wasn't the simplest engineering, it is more complicated than drilling 2 holes and buying the caroni pulley and quill. Decisions await.
4,913
OK, from looking at the latest pictures (4 of 5 is best..), I'd get a machine shop to
0) remove the old bearing inner race
1) cutoff the damaged threaded section
2) drill into the spindle ,say 1-1.25"
3) tap the hole
4) lightly 'cleanup' the entire shaft. Leave new bearings there ,so they can fit properly.
I'd think $100 would be a fair price for the labour and time.
The bolt only has to hold the pulley on, no real stress, that's what the Woodruff key is for. When assembling, coat bolt well with neverseize,install, remove, dab a little more NS, then final install.
Jay
haanzel
Jul 30, 2014
122
Jay, FYI, the threaded end is where the blade goes on. I don’t know if that changes anything with regards to drilling and tapping? I’m not an expert in this area.
4,913
won't matter , as the stress is on the Woodruff key NOT the nut. The nut( or bolt head) is just there to keep the blade( or pulley) on the shaft.
when assembling, use lots of neverseize on the pulley and blade adapter too ! put on NS, assemble, remove , brush a bit more on, the reassemble for good.
Jay
haanzel
Jul 30, 2014
122
just an update. I emailed 4 shops, 3 replied back. One quoted $400 to make a new one! Ouch. Another asked to bring it for an inspection as he though he could fix it. Well, he has looked at it and is going to 1) try to fix it, price is about 35-40, or 2) make a new one at $100. I said to do both so I have a spare, so worst case, he makes 2 of them. I am really pleased with this and should get them back early next week.
4,913
sounds like you forund the right place !
I just had a guy estimate to sandblast my Millcreek25 spreader....
$1000 !!!! Hmm maybe, MAYBE an hour to do the job
haanzel
Jul 30, 2014
122
That is ridiculous, even in Canadian dollars. 2-300 would be a rate around here. Keep shopping Jay.
BXHoosier
BX24
Jan 21, 2018
484
556
Indiana
A ridiculously high price usually means they do not want to mess with it but they are willing to screw over someone if they are crazy enough to pay a stupid price.
6,399
Go buy a compressor and a soda or sand blaster for that price and do it yourself! ;)
4,913
sand blastin... BTDT..still have 2 compressors and pot, jes waaay tooo messy, local guv has shut down most places.
good thing is the spreader is all flat surfaces ,so RA sander and several discs. I'd rather pay 200 than spend the day doing it..rather have more quality time on the BX23S !
twomany
B7200
Jul 10, 2017
793
138
Vermont
That was the shop I wanted to send you to, I still can't remember the name ;-))
GOOD OPTION!
