water flange L2650
mickey harmon
L2650
Jun 18, 2019
bartlett
can anyone help me? I need to replace the water flange on my L2650, and to get to the bolts behind the water pump is very tight. what all would I have to take off to get to them.
5,585
When I had an L2050 and had similar repairs needed, here's what I made to do the job. Just took an older box end wrench, cut it off and welded it to a not good screwdriver. I ground the outside of the wrench to make it narrower to fit in. It's slow, but it beat removing the head to get to it!!
6,409
To get to it without a tricky wrench like D2Cat shows (I have one somewhere that is similar) you either have to pull the gear case or the the head. :eek:
5,585
Check with your local High School to see if they offer any welding classes, or Junior College.
Now days you can get a welder for under $200, watch some YouTube videos, and start melting some wire. You soon get better at the process and amaze yourself....but you have to get started!
SidecarFlip
Banned
555
Anyone can weld. especially with a 'glue gun' (Flux core MIG). Skill level is somewhere between a rock and a Democrat.:rolleyes:
