Hello, I hope someone can help out a new guy with an old tractor. picked up this tractor used after only having ever rented hydrostatic transmission tractors and I'm having a tough time figuring out how to run the loader and drive the thing at the same time. I thought I'd just find the answer on youtube but it doesn't seem like anyone makes videos on these older tractors.
Do you generally pick one gear to work in and just use the front/back lever to change direction or do you have to start in the lower gear to save the clutch like a car?
What I have been trying so far is to push into a pile in high range 1st gear, push the clutch in, revving up the engine to lift, shifting to reverse and letting the clutch out again, is that the correct procedure? I've been stalling it a lot doing that and have not mastered curling and lifting at the same time so it's all kind of clunky looking.
Any advise would be appreciated!
