Well of course you need to change your fuel filters then! It never fails that you must work on the fuel system when the tank is full!that would be a neat trick, since we'd just topped it off. lol
Gosh isn't that the truth!!!Well of course you need to change your fuel filters then! It never fails that you must work on the fuel system when the tank is full!
Gee, thanks for pointing that out.... I may have to siphon my own tank...Gosh isn't that the truth!!!
Sent from my QTASUN1 using Tapatalk
Dggott - EVERY time I do anything fuel, tanks is full...never fails...Gee, thanks for pointing that out.... I may have to siphon my own tank...
I assumed fuel filters, but thought it maybe a bit odd that it just died like that and thought maybe if I let it sit and it is the filters, that enough might pull through to start it again, but no. Would think that if it was air filter, it would have coughed and wheezed some. It wouldn't be a timing chain or something, would it?
We bought it used with 1600 hours on it. I'm guessing it's been a good long time since fuel filters were changed, though
It shut down as if you turned the key??? No stumbles first, etc....? I agree air or fuel could/should make it stumble some before it quits.
I'm going by my BX2360, but when it shuts down, 5 seconds later I hear the Stop Solenoid reset so it's ready to start again....think maybe that or electrical/key switch, etc?
Filters need doing anyway, so start there.
I wouldn't just throw parts at it, but maybe some electrical troubleshooting is warranted...i.e, lift pump, stop solenoid.
Just a couple thoughts, and certainly wish you the best to finding the fix.
when you described it dying - you said it quit, so it didnt stumble? A diesel that stares for fuel stumbles....like it wants to run but cannot...then chokes out.I just went out to see if it will start. Nope, but it did try. Blew a little smoke, tried to fire, but just couldn't keep it going. Based on that, I'm guessing it is fuel, but then maybe that's wishful thinking?
Yep - if it did indeed stumble before and is now trying to fire w/ some smoke, I'm guessing fuel too.I just went out to see if it will start. Nope, but it did try. Blew a little smoke, tried to fire, but just couldn't keep it going. Based on that, I'm guessing it is fuel, but then maybe that's wishful thinking?
Super - - good for you!!Now, to figure out where we bought the water. lol
