Hello,
New to the forum. I have a B7100 i inherited that has been siting for 5-6 years with no block of wood on the clutch pedal. It was grinding when trying to get it into gear as well as trying to shift the PTO. I have only driven the tractor about 100 yards since getting it. I knew it a problem so i dug into it.
To my pleasant surprise the clutch looks like new no rust at all on the flywheel. I did find the throw out bearing to have a little rough spot on it. But i dont think that would cause the terrible noise i was hearing. I did find the pilot bearing disintegrated. Further inspection got me to the PTO lever not going into position #3. I drained the oil of of the tranny and pulled the cover off. I can see 3 detentes on the shaft closest to the lever and its only moving from 1-N-2 (not gettting to N-3).I can see the gears sliding on 2 shafts but cant see why it would be stopping Is there another gear that moves or something i cant see? I would like to know how this is supposed to work before i rip it apart. Does the tranny high/low lever have an effect on it? 4WD lever? The tractor is still split at this point
Thanks in Advance!!
Thanks in Advance!!
