B7200 automatic trailer hitch
Duffsfarm
B7200D, B7200DHST, G3HST, KMS 180 Backhoe
May 22, 2014
24
Drogheda, Louth, Ireland
I made an automatic trailer hitch for my B7200. The trailer hook is lowered by the 3 point arms. You then reverse back to the trailer until the hook is under the towing eye and then lift the hook. The latching mechanism automatically locks the raised hitch in place. I have posted a video on You Tube showing the operation.https://youtu.be/eqAjgoCl-dg
bcp
BX2360
Apr 20, 2011
645
78
SW WA
I was about to mention that you had probably seen that system on some European tractors, but then I noticed your location.
:D
Bruce
6,397
Does it have a stop to keep it from going too high?
hope to float
L3450
Feb 18, 2018
474
61
Ireland
I want :cool:
Duffsfarm
May 22, 2014
24
It is a typical European style hitch, unfortunately Kubota don't make one, hence the home build. The hook is from a hitch off a Ferguson 20, I just fabricated the mounts, latching mechanism and lifters. The hitch always comes up to its final latching height which is fixed. It is all set up so that the 3 point arms raise to their maximum position to engage the latch. Once the hitch is latched the arms are lowered to normal position. To unlatch, the arms are lifted to the max position which takes the pressure off the latch, the release lever is pulled to open the latch, and the arms are lowered to let the hitch down. The system works equally well with a loaded or empty trailer.
