Hey guys...I sold the old 1974 B6000 that I've had for a couple months (at a very favorable price too), and now I'm looking for a little better machine. I know I want 4WD, HST, power steering, loader, ROPS, mower, and at a good price, even if that means high on hours or some dents and dings.
There are two candidates locally and/or within a reasonable drive at a good price:
- 2001 B7500 w/FEL and RFM, around 700 hours...mostly used for bushhogging a pasture. Doesn't appear from 1 pic and a phone call to have been meticulously maintained...
- 2006 BX1850 w/FEL and MMM, around 600 hours...mostly used for mowing I gather, and I also suspect hasn't been maintained meticulously. (The seller replaced the hood with a new one...I would guess he dropped something off the loader bucket onto the hood and damaged it.)
I think both of these are good candidates, both are pretty low hours. I can catch up on maintenance as long as they're not broken-down and barely operating. I ain't buyin' a piano...I'm OK with it having some dents, dings, a little rust, a few minor things that don't work, etc. I suspect either one is going to be at least a little better shape than the old B6000 I just sold, even if it's only because they are 25-30 years newer.
Both of these are a little bigger/heavier/stronger/more capable than the B6000...I believe I'm probably leaning toward the B7500 though. I *think* I'd prefer a MMM, but I'm actually not sure, can see benefits/drawbacks to either MMM or RFM.
So, here're my questions:
Q1: For each of these, what should I be checking out and examining to make the buy/pass decision?
- Engine...starts easy, minimal black smoke/no other smoke, oil clean, no froth in oil after running, no visible leaks, coolant clean/no floaters...anything else? How can I check if it overheats too easily?
- Loader hydraulics...level OK, no visible leaks, loader cylinders appear strong, pins greased, etc.
- HST drive...what am I checking here? (I recall seeing someone once say "put the brakes on hard and try to drive it forward...if the HST isn't tight enough to stall the engine, then there may be a problem"...is this correct or no? It actually sounds like a good test...presumably, there's a hydraulic relief valve that should open at some point.)
- Front drive assembly: I saw someone complaining about bearings/casting being aluminum and wearing out on the B7500...check for leaks around the front drive? What else here?
Q2: The B6000 had a separate hydraulic pump and reservoir for the loader hydraulics...I'd assume both the B7500 and BX1850 run the loader hydraulics off the HST drive...correct? Are the extremities of the transmission/drive components lubricated by the HST fluid, or are there multiple reservoirs to check?
Q3: Any common/systematic problems with either of these that I need to look for? I believe mowing clogs the radiator fins of both, IIRC. What else?
Clearly, that old B6000 was a rugged little tractor, or it wouldn't have been still running and fully useable after 40+ years. I'm hoping to snag something just as rugged with the stuff I need/want, and I'm OK if it's just a little beat up as long as the mechanical shape is good. I do want to avoid picking up something that's going to take thousands in repairs that I can't do myself (I'm reasonably handy...can change fluids, fix wiring/lights, weld cracks, change hydraulic hoses, etc)...so engine, drivetrain, etc., need to be in good useable shape.
Thanks and cheers!
Thanks and cheers!
