I have a 2004 L4330 Kubota tractor with a cab. It has 1000 hours and runs great except for the A/C. I have replaced the compressor, the evaporator, A/C switch in the cab, relay switch in the roof, installed a new expansion valve located in the roof. I cleaned the condenser coil and fan unit located in the roof. I vacuated the system and charged the system with Freon. The gauges read 45 on the low side and 250 on the high side. I am getting air in the cab but it is not even cool. The A/C switch in the cab is lit indicating the A/C is on. The compressor is running and the lines at the compressor are sweating and there is condensation running out of the drain tube located under the tractor. I did notice the sight bubble in the evaporator was hazy after we charged the tractor with Freon. Is there another relay in the roof that needs to be replaced? The local dealer does not work on A/C so they have been no help. Is there a manual that deals with A/C in Kubota tractors? I am not sure what else to do at this point. Any suggestions?...Thanks...DMcIntosh
