Engine oil leak
Jtryan
B2320
Jan 17, 2016
55
Ottawa, Ontario Canada
I change the engine oil on my b2320 3months ago and I notice that everytime I use tractor (5 times since oil change) I see a spot of oil under tractor on the frame itself and not the garage floor. It's in line with oil filter.
Is this just oil stuck in the frame and it's working it's way out?? I can't find any where else it could be leaking
2,426
When you changed the filter......are you sure the old gasket came off, and the mating surface was clean?
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
My fellow Ottawan .. wipe down/pressure wash what you can, then wrap tissue or paper towel around the filter. If it gets oil stained the filter is the culprit ..
