I have a 2016 BX2670 with a ride over rotary mower (MMM) the mower is a model RCK54D-26BX. During my recent abuse of the tractor while clearing brush is was operating the tractor without the MMM in place.
One of the things that happened was that the Universal Shaft Joint became dis-engaged from the rest of the Universal Joint assembly and fell to the ground.
Yesterday I crawled under the tractor to look at how it all was supposed to go together and tried to return the joint shaft to its intended position. I was hopeful that if a branch knock it loose I could simple put it back.
For some reason the the joint shaft and the yoke sleeve did not seem to go together I could just barely get it started.
So I was wondering, is there a trick to it or do I just have to remove the assembly from the tractor, clean the heck out of eveything, re-lube and re-install the assembly.
Any words of wisdom or guidance would be appreciated.
