I set the torque to 20 lbs on the first go around. I wasn't able to pull the wrench in on smooth turn because of the damn hood in the way so I kept having to reposition it on the bolt. It worked on the 20 lbs setting but seemed to not want to click on the 30 lb setting on the 2nd go around. It felt like I was pulling with more to hand 32 lbs and then the bolt snapped. Luckily I was able to unscrew the broken ends from the block but now I have to replace the brand new head gasket.
Is there some reason the torque wrench isn't clicking at the right poundage?
