Harbor Freight Quick Hitch & Titan Heavy Duty Hitch
LMTractorGuy
L2501HST, LA525, RCR1260, BB1260, Titan 48" SS Forks, Stump Bucket
Sep 20, 2016
70
SC
So I have both. Here are the pictures. I do not have the quick attach bushings installed yet, so that would raise the Titan hitch about 5/16" more. The Titan hitch will not come close enough to the HF quick hitch for the top pin to fit. I have marked out the area I am considering grinding off of the HF Quick Hitch in one of the pictures so I can use it. Anyone else using this setup and maybe provide advice? Thanks!
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
From the angle of the photos, it doesn't look like it will clear they lower bolt for the top link attachment even if you grind off the lower corner.
Mike
bmblank
Mar 4, 2015
663
294
Cadillac, MI
You have to remember, the hook has to go below the pin far enough to take it on and off. The way it is now, you won't be able to get the pin off the hook, by the looks of it. Unless you're planning on inserting the pin after the fact.
Sent from my XT1254 using Tapatalk
bcp
BX2360
Apr 20, 2011
645
78
SW WA
Don't grind off any holes that will prevent you putting the top hook the standard QH height above the lower hooks. (Fifteen inches centerline separation)
This is why many users either use the adapter from HF or weld a spacer on the hook so it sticks back about an inch more.
Bruce
LMTractorGuy
Sep 20, 2016
70
SC
Would the adapter make it lean back too far? Would I adjust the top link to compensate and level out? Thanks for the help.
LMTractorGuy
Sep 20, 2016
70
SC
Here is a top link adapter bracket by Agri Supply. Harbor Freight has one also but it does not show online. You have to call HF and order part #29309 for $15.99. Does anyone know if the brackets are the same? Would this make my Trailer hitch work? I also have a Land Pride RCR1260. Many people talk about needing a floating top link for a Rotary Cutter so I will probably need it for that anyway.
jajiu
Jun 5, 2016
456
112
Rowley, Massachusetts
LMTractor Guy, I have had 4 tractors and used a couple of different QH's and never been able to use the hook. I have always used the adapter. It works great and just adjust the top link to compensate.
bcp
BX2360
Apr 20, 2011
645
78
SW WA
The cutter probably has a floating link hitch already. For quick hitch use it needs to be behind the A-frame instead of in front of it.
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
691
115
Southern IL.
Not sure what you decided to do but I bought the top link you posted and it works great. As others have said, I couldn't get the hook to work so I moved on pretty quick. The only adjustemnet I do is to lengthen or shorten the top by screwing it in or out depending on the implement.
I'm sure it will say I'm the instuctions but the top link, quick hitch and the the adjustable bar, not sure what it's called, all share the top pin. I'm sure you would figure this out but I thought I would mention it anyway.
Please post back what you decide to do. There's been a few questions on here about getting the hook to work and I'm not sure many folks use it, I could be wrong tho. It's just good to have all the info out there for other to see.
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
The Titan isn't quick hitch compatible. Nothing wrong with the Quick Hitch.
LMTractorGuy
Sep 20, 2016
70
SC
I have ordered the top link adapter from Harbor Freight. I will post pics of it hooked up once I receive it. Thanks for all the help.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
as jajiu says it is not usual to find some attachments that use that upper hook. The way i do it is just have some inks made up.
By the way, when buying attachments to use with the QH, it is a good idea to have the dimensions of the QH handy so yu don't run into the situation shown here.
Welding added attachment places on that HF QH should work fine also. It is well built.
LMTractorGuy
Sep 20, 2016
70
SC
Can I use the top link adapter from Harbor Freight or do I need to have them custom made? If you have any pictures of how I would attach the Titan Heavy Duty Hitch using the top link adapter to the HF quick hitch that would be helpful. Thanks.
armylifer
Mar 26, 2013
2,051
784
Thurston County, WA
Can the top hook be turned upside down? It does not bear any weight anyway so if it can work upside down you have the solution.
LMTractorGuy
Sep 20, 2016
70
SC
Armylifer. Good idea, but the 3 point Titan trailer hitch hits the HF QH and will not allow the top hook bolt holes to line up.
clay45
Feb 6, 2015
279
SC
sgtboz
Kubota L3800/L3940, BH77/BH90 Backhoes, www.bozhog.com
Sep 11, 2015
197
Oklahoma City, OK
www.bozhog.com
I have had times where, in a pinch, I rotated the hook and used it as 'pictured' per the green outline. Try not to envy my artistic skill, here.
But I've both box bladed and brush hogged (both 6') *extensively* with the hook in this position and yes, that was with just one hitch pin in the hook. In my setup, the hook isn't long enough to rotate out of position and lose contact with the implement. As long as you only have down force on the implement, it'll hold. It's not ideal but it worked flawlessly and is more what Uncle Sam taught us as "field expedience." I now use the Harbor Freight adapter in all applications and never use the hook. But if you need a way to get by quick without welding anything, I recommend this orientation as a stop gap.
