Hi, New to this group. Lots of great info in here! Could not find an answer to my issue though.
I have an 1998 or so L35 with the Clutch and left hand shuttle shifter for Forward/Neutral/Reverse and the 8 speed selector on the left. I think it is the HST, not the DT, but it does not say GST anywhere on the fenders, etc. It does have a couple of thousand hours on it, the last 400 or so by me over the last 15 years.
Now the problem: in the last couple of months, I have been getting gear grinding when going between Forward and Reverse. Initially, it would go in finally after the engine slowed a bit (clutch in), but now it will not go in at all unless I put the gear selector into 0 - Neutral. Then it shifts between forward and reverse fine (still using the clutch for it)
I can change between gears 0-8 without needing the clutch while moving, so that part seems to be OK. (which makes me think it must be the HST model)
The clutch does need the throwout bearing changed, as it makes a scraping sound in neutral until I press on the clutch. But the clutch does not feel like it is slipping and the pedal feels pretty well adjusted. All the hydraulics work fine.
Hoping someone has an idea what this might be and if I could adjust or repair something without having to split the transmission and take it all apart.
