L3800 Tool Box Improvement
tedtf
L3800 HST
Mar 21, 2016
Kansas
I wanted a bigger tool box for my L3800. I did not need a lot bigger, but something that would improve on the current pencil sized box. Found this and bolted it on today. Gives about 3 times the size of the OEM tool box.
https://www.tiredirontractorparts.com/tractor_parts/tool-box-plastic-17-000-x-6-625-x-6-000-a-tb17000.html
I lined up the right predrilled hole in the tool box bottom and simply used the bolt from the OEM tool box to hold it in place. Then I marked the other factory Kubota hole and drilled into the tool box bottom in order to use the other factory Kubota bolt. Took 5 minutes.
[/URL][/IMG]
Tooljunkie
May 13, 2014
4,150
Can never have a big enough toolbox. Will get you by for now.
Looks good. All i have is the little cigar box under seat and it has bare essentials.
JasonW
295
137
Al
Looks good. I did something similar on my 3800, now it just hinders my view when using the cutter.
