RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
I was told the same thing. I also was told you are not going to move a mountain.............. I disagree YOU CAN it is just going to take a bit longer.I am so impressed with this so called "Lawnmower on steroids", and the salesman was afraid it might be too small.
To say the least, wouldn't have been easy or even possible without a little guidance from Harry. Added several accessories from BXpanded to speed up the work. Next on the wish list are the extended stabilizers and the BH dolly.Impressive little beasts aint they
I have moved a mountain, it just took 1,000 bucket loads. Now the mountain is where I want it to beI was told the same thing. I also was told you are not going to move a mountain.............. I disagree YOU CAN it is just going to take a bit longer.
Just got the ripper and dolly. Don't know how I did without them!To say the least, wouldn't have been easy or even possible without a little guidance from Harry. Added several accessories from BXpanded to speed up the work. Next on the wish list are the extended stabilizers and the BH dolly.
The ripper has been amazing, 2 or 3 passes with the hoe and most stumps under 6" are out & no moving.
http://bxpanded.com/index.php?l=product_detail&p=64
Yes and no, Eventually will get the the full set, but for now I ordered the BH dolly and fat pads from BXPanded. Need to save up for the extended stabilizers. Will help on hills, especially working sideways which I will be doing in the spring.Hey Ron,
when you say "Next on the wish list are the extended stabilizers" - you mean a bigger footprint? If so - I have thinking the same thing - Paul Short - aka WILDFIRE here, has made a set - looks very nice too. I am thinking of adding onto the original, rather than replace......
