L4630 front axle leaking
6,351
You need to check both.
I'll send you an email with a link to download the WSM (Work Shop Manual) to help with taking it apart and repair. ;)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
I would check to see if it's building up pressure in the axle case. Summer heat and hard work can cause excess pressure and make them leak.
OldMasterTech
KX057-4, KX121-3, L4630GST, RTV1100, AT60, T1700, T1560, 555E
Mar 28, 2011
30
Massachusetts
I am new to a forum, I have a front axle leak on the right side. What do I need to check? seals or bearings. thanks
Retiredcop, did you ever perform this repair? What was the complexity? My L4630 is leaking bad left front axle from the largest pivot joint.
