In op block heater BX 2370
Elkers
Bx2370, MMM, 50' blower, ballast box, piranha tooth bar
Sep 10, 2014
Elk Rapids Mi
The block heater on my BX stopped working after only using it twice. The tractor has just turned over 50 hours total time since new in July of this year. AI don't see where it gets any power from the tractor so I assume there is not a fuse connected to the heater. It has to go in for its 50 hr service in the next couple of weeks but wanted to see if anyone else has had this issue and what they have done to remedy it. Thanks
2,551
Ok, let me ask the first dumb question, not trying to be a smart a$$ - how do you know it stopped working ? because it does not get hot to touch? The cord that is being used, checked all that ? I would plug something in the duplex outlet you are using, verify the 120 v is there, and then test the cord, then take a ohm meter and check the two prongs on the end of the heater, I would think an Ohm test would show something close to zero ( maybe <100 ohms)
do all that and check back with us:)
bearskinner
Sep 1, 2014
926
241
N. Idaho
I can feel the warmth on my block when its been plugged in for a half hour or so.
uglyboy
TG1860G
Mar 8, 2013
87
St. George, Ontario
from reading the OP's comments, maybe he thinks it is powered from the tractor battery ???
Probably obvious to most of us, block heaters have 3-prong plugs, need to be plugged in to your house/garage/barn power outlet.
Pete
Elkers
Sep 10, 2014
Elk Rapids Mi
Thanks for all the replies, I have checked the outlet, the extension cord to the block heater and all checks out fine. I'll get back with the results of the test.
Tooljunkie
May 13, 2014
4,150
The block heater on my mom's car has 28 ohms resistance, is 450 watt heater. Just serviced it and tested heater.
A really good investment is something called "Plug Alive"
Shows wall current and if the intended load is working.
Is 20 dollars up here.
I keep forgetting to pick one up. Had one in my toolbox, someone needed it more than me.
