Hello all:
I have a 2010 Kubota B3300 with a 64" rear PTO snowblower. On at least 3 occasions now I have hit a large stick buried under the snow that jams the impeller causing the whole tractor/engine to IMMEDIATELY shut down. I mentioned it to the dealer once, concerned about damage to the transmission/ PTO and they didn't seem terribly concerned as long as it doesn't happen too often. To me, it seems like a really bad thing to have a PTO shaft cranking at about 500 rpms and an engine moving at 2000 rpms to instantly cease because of a jammed implement. No? Am I causing serious damage to the tractor and is there some adjustments that need to be made? I thought that was the whole reason for shear bolts; to break when under severe load to prevent undue stress on the tractor and PTO. It is a rather large blower, perhaps "weaker" shear bolts should be installed given the lower HP (33) of the tractor? Any input would be much appreciated. Thanks!
