I have the Construction Attachments one touch third function valve. I have installed it just like the videos and it works my grapple great. From the beginning I have had fuse problems, it will blow a fuse almost every time I use it. This is the electric over hydraulic valve. I only has two wires to mess with, one to power and the second to frame ground. It is wired to a red/white wire in the Kubota MX5100 just like the instructions and the ground to frame near the unit. This is the second one I have had, the company sent me a new one after relating this problem before. I have talked to the engineer and he is at a loss. I have checked for frayed wires, nicks, increased the fuse to30amps instead of 20amps. Completely changed out the power wire connections, moved the ground wire, still blows fuses. What else can I try, I love this grapple. What is the principle that causes to fuse to blow? any help will be greatly appreciated.
