Awesome job! What materails did you use? I would like to build something similar.Here is my light bar I made this week end . Cheap lights , but they work well and the tractor seems to handle all of them fine .
Awesome job! What materails did you use? I would like to build something similar.[/QUOTE
I just used what I had laying around . The cross bar is a piece of two inch c channel and used to pieces of half inch by one inch for the supports . Drilled my holes in the supports for the square u bolts and drilled the holes in the c channel for the lights and their wires . painted the whole thing and then ran my wiring for the lights, that took the longest . Wired up to the battery with relays and fuses and used quarter inch wire protector on all of it , zip tied all up nice and neat . Mounted the switches by my three point raise lever . the lights are cheap ones from pep boys but they work well . I have tried led's before and didnt care for the bright white light while snow blowing . Thats why I went this route . Thanks for the comments all Some times you just have to use what you got ,lol .
Thanks for the info. Looks awesome.Awesome job! What materails did you use? I would like to build something similar.[/QUOTE
