rather than weld to the bar, weld on a slab of steel and bolt it TO the bucket, yes it will get clogged up and stuff with dirt or whatever.....but it will serve the purpose - and you can take them off if need be- true there will be a few holes in your bucket.....but wth .....aint like you are transporting water!Title pretty much says it all. I got some good feedback from the other site that it might not be a good idea. Thanks
Sounds like a plan. Thanks for your input guys!rather than weld to the bar, weld on a slab of steel and bolt it TOO the bucket, yes it will get clogged up and stuff with dirt or whatever.....but it will serve the purpose - and you can take them off if need be- true there will be a few holes in your bucket.....but wth .....aint like you are transporting water!
picture shown is bolted on top side of bucket, but you get the picture, two grade 8 bolts .....booya .....solved!
