First, if my search FU is weak, please point me to a good thread. I have read a bunch of "fork" threads but, I'm almost as confused now as when I started.
For my LA764, anything over 2,000 pounds is overkill and will probably take away from my lift capacity. I believe I have the SSQA option since I have the grey handles at the top of the bucket for a quick attach/detach for the bucket.
For tine length, the shortest I will consider is 42" with a strong preference for 48" and 60" being the maximum length (i.e. too long reduces lift capacity and makes it harder to maneuver since I don't want extra holes in my barn or enclosed trailer). A higher load rated fork would allow me to use it later on a larger tractor so, that is a factor as long as the weight doesn't become unreasonable.
Initially, I'm looking at these fork options:
Are any of these particularly better than the others? Where is the "sweet spot" for price vs. quality vs. capability? Where does the factory Kubota forks fit into the mix (i.e. how much do they cost, are they better, or the same as the others, etc.).
Best Regards,
Sid
- Titan, 60" Skid Steer Heavy Duty Pallet Fork Attachment
- Everything Attachments, Construction Attachments X-Treme Duty Pallet Forks Model 1PFHL
- Landpride PFL
- Kubota factory forks
Best Regards,
Sid
