i have a l295 dt kubota and only have one forward gear in low and high. i removed the shifter cover and the plate underneath it to check and see if any thing was broken or loose. after a couple hours of trying to line every thing back back up, i finally got it put back together. it was really low in fluid so i topped it off and started the tractor only to find that the other gears still were not working. it appears i only have the lowest gear and reverse working. does anyone have any ideas on what the problem may be and a fix that hopefully does not include a total trans rebuild
