zg222
shotgunn410
kubota zg222
Apr 19, 2025
ms
So I pressure washed my zg222 and now I'm not getting power to the fuel pump. Fuel pump turns on when voltage regulator is disconnected. Any help with this would be greatly appreciated.
5,532
It sounds like regulator has been damaged. I think that one supplies power when engine is running though need wiring diagram to comfirm.
You 'might' get lucky , if you use hairdryer for 10-15 minutes, to gently remove all the water from both regulator and connector. 'might'........
Check online for a new regulator, while hair dryer is doing it's thing.....
